Best way to export PST contacts to VCF for iPhone and Android?
tylerhoward
If you’re trying to move contacts from an Outlook PST file to your phone, converting them into vCard is basically the only smooth method. Phones don’t read PST files directly, so first step is getting them into VCF format. I tried the manual method earlier and it took forever, especially with hundreds of contacts. Using a converter was much easier because it exported everything together and kept all numbers, emails, and details properly arranged. Once converted to VCF, I simply imported the file into my phone and all contacts showed up instantly. WholeClear PST to vCard Converter worked well for this since it handled the full contact list in one go. No missing details, no messy formatting. Just a ready-to-import VCF file for Android or iPhone.
