How are businesses combining contacts from Outlook, iCloud, and Android exports?
We're migrating company-owned devices and discovered that employee contacts are stored across multiple platforms. Some contacts were exported from Outlook, others came from iCloud backups, and several were saved from Android devices. As expected, there are duplicates, missing fields, and inconsistent formatting between exports. Before we start importing everything into a central system, I'd like to understand how businesses usually handle contact consolidation from mixed sources. Is there a recommended approach for combining contacts from different ecosystems while keeping phone numbers, emails, and notes intact?
For mixed contact exports, the first step should be cleaning and sorting the files source-wise. Keep Outlook, iCloud, and Android VCF exports in separate folders first. Then make a backup before doing any merge work.
In one similar case, Softaken Merge vCard Tool was useful for combining selected VCF files into one contact file. It allowed previewing contact details before merging, so fields like full name, company, business phone, home phone, and mobile number could be checked first.
It keeps contact structure and saved details like text, numbers, and symbols during merging.
Businesses commonly combine contacts from Outlook, iCloud, and Android exports by first exporting contact data into standard formats such as CSV or vCard (VCF). They then use contact management, CRM, or data migration tools to import, merge, and deduplicate records from multiple sources.
