How can I connect flash drive for iPhone?
To connect a flash drive to your iPhone:
  1. Use a Lightning to USB adapter (or USB-C for newer models).
  2. Plug in the flash drive to the adapter.
  3. Open the Files app to access its contents.
    Make sure the drive is compatible with iOS and properly formatted.
To connect a flash drive to an iPhone, use a Lightning to USB adapter (for older iPhones) or a USB-C flash drive (for newer models like iPhone 15). Plug the flash drive into the adapter or port, then access files through the Files app. Make sure the drive is formatted as exFAT or FAT32 for compatibility. Some flash drives are designed specifically for iPhones and come with their own apps for file transfer.
To connect a flash drive to your iPhone, you need a Lightning to USB adapter (for older iPhones) or a USB-C flash drive (for newer iPhones like the iPhone 15). Plug the flash drive into the adapter or port, then open the Files app on your iPhone. You’ll see the drive appear—just tap it to view, copy, or move files. Make sure the drive is compatible with iOS.
