techeianjali
Member
To fix the Outlook not opening issue quickly, try a few simple steps. From my experience, start by opening Outlook in Safe Mode (press Windows + R and type outlook.exe /safe). This helps identify if faulty add-ins are causing the problem. If Outlook opens, disable unnecessary add-ins.
Next, check for a corrupt Outlook profile and create a new one from the Control Panel. You should also ensure your system and Outlook are updated, and temporarily disable antivirus software to rule out conflicts.
If Outlook is still not opening, the issue may be due to a damaged data file. In such cases, using a professional PST repair solution like BLR Tools can quickly fix the corruption and restore normal Outlook functionality.
