How Do I Choose the Right Monitor Mount for My Setup?
I’m planning to upgrade my desk and considering a monitor mount, but I’m unsure which type to go for. What factors should I consider before buying one?
considering the latest 2026 trends, ergonomics is also key, look for a mount with adjustable height and tilt for a comfortable setup
a key factor to consider in 2026 is the type of mount, with wall mounts and desk mounts being popular options, look for one with a smooth tilt and swivel mechanism for easy adjustment
consider the displayport version of your monitor and mount, recently updated to version 2.0 in some 2026 models, for better display quality and connectivity options.
recent 2026 reviews highlight the importance of displayport 2.0 compatibility in monitor mounts for seamless connectivity and high-quality display.
considering displayport 2.0 compatibility is crucial, as it supports higher refresh rates and resolutions, such as 8k at 60hz.
