You can connect your laptop to a TV in several ways. The most common and easiest method is using an HDMI cable, which provides high-quality video and audio. If your laptop has a USB-C port, you can use a USB-C to HDMI adapter for the same result. For older devices, a VGA cable can be used, but it requires a separate audio cable. Wireless options include Miracast, Chromecast, or Apple AirPlay, allowing you to mirror your screen without cables. You can also stream media over Wi-Fi using DLNA-supported apps. Choose the method that best suits your devices!
