I’ve got RGB LED strips in my PC, and I’m not sure how to control them. Do I need specific software or hardware? Any tips would be appreciated. Thanks!
@Olivia, To control RGB LED strips on your PC, you need to determine whether your strips are connected via your motherboard or an external controller.
STEP 1: Install the correct software from the motherboard manufacturer’s website.
STEP 2: Launch the software and customize lighting effects, colors, and sync with other components.
Other Options
USB or External Controller RGB Strips
If your strip connects via USB or includes its remote.
Others may not offer software control; you’ll use a physical remote or a dedicated app.
