How do I convert PST contacts into CSV format?
Converting PST contacts into CSV format is pretty easy with Microsoft Outlook.
First, open Outlook and go to File → Open & Export → Import/Export. From there, select Export to a file and choose Comma Separated Values (CSV). After that, pick the Contacts folder from your PST file, choose a location to save the file, and complete the export process. Your contacts will then be saved in CSV format, which can be opened in spreadsheet applications like Excel.
From experience, this method works well for smaller contact lists and quick exports. However, when handling multiple PST files or large amounts of contact data, the manual process can become repetitive.
For a more efficient workflow, the BLR PST Converter Tool can simplify bulk exports and help keep contact details organized during conversion.
Also, using a reliable PST file converter makes managing large PST files much easier and reduces the chances of missing information during export.
So, Outlook’s built-in feature works great for basic needs, while dedicated tools are more convenient for larger tasks.
honestly, pst to csv conversion is really getting streamlined, especially with the growth of artificial intelligence in 2026, making it way easier to manage contacts and data.
yeah, converting pst to csv is pretty straightforward now, especially with cloud-based tools emerging in 2026, it's getting way easier to manage contacts and data, honestly.
ugh, so many pst to csv conversion questions, anyway, with the 2026 trend of cloud-based contact management, it's getting kinda easy, tbh, just use a reliable pst converter tool and you're good to go, honestly.
yeah, honestly, pst to csv conversion is super easy now, especially with cloud tools emerging in 2026, i mean, it's a no-brainer, just use a reliable converter tool
ugh, honestly, pst to csv conversion is a breeze now, especially with 2026's cloud-based contact management, tbh, just use a reliable converter tool, wait, it's getting way easier, actually.
So you're getting the "this site can't be reached" error, that's frustrating. I've been there too, and usually it's due to a simple issue like a typo in the URL or a problem with your internet connection. Try checking your Wi-Fi or restarting your router to see if that resolves the issue. If not, you can also try clearing your browser's cache and cookies, or checking if the site is down for everyone or just you by using a site like DownDetector. Sometimes it's just a temporary glitch, so waiting a bit and trying again might also work.
To convert PST contacts into CSV format, open Microsoft Outlook and go to File > Open & Export > Import/Export. Select Export to a File, choose Comma Separated Values (CSV), and then select your Contacts folder. Choose a save location and finish the export. If Outlook isn’t available, a PST conversion tool can also help.
