How do I enable two-factor authentication on Instagram?
riyanroshan
Go to Instagram settings, tap Security, select Two-Factor Authentication, choose a method, enter the code, and enable 2FA.
  • Open Instagram Settings → Go to your profile settings.
  • Tap on "Security" → Find the security option.
  • Select "Two-Factor Auth" → Choose the authentication method.
  • Enter the verification code → Verify using SMS or app.
  • Enable & SaveSettings→ Your 2FA is now active.
To set up two-factor authentication on Instagram, you must follow some of the given steps below.
1. Start by going to your profile. Tap the menu icon (three lines) in the top right corner, then select Settings and Privacy.
2. Next, go to Accounts Center > Password and Security> Two-factor authentication.
3. Choose the account you want to secure, and then pick a security method: Authenticator app, Text message (SMS), or WhatsApp.
4. Follow the instructions on the screen to finish the setup.
After it's enabled, you'll need a verification code in addition to your password to log in, which will help keep your account safe.
You can enable 2FA on Instagram by clicking the menu (☰) icon to reach Settings and privacy followed by Accounts Center > Password and security > Two-factor Authentication. Start by choosing your account after that select Authenticator app SMS or WhatsApp authentication followed by step-by-step instructions, provide the OTP and finish the process.
To enable two-factor authentication on Instagram:
  1. Open Instagram and go to your profile.
  2. Tap the menu then Settings and Privacy.
  3. Select Accounts Center > Passwords and security > Two-factor authentication.
  4. Choose a security method (Authentication App, SMS, or WhatsApp).
  5. Follow the prompts and confirm the setup.
  6. Save your recovery codes for backup.
Here are the steps that you have to follow to enable 2-factor authentication on Instagram:
  1. Log into your account
  2. Then go to settings
  3. Find the Two-factor authentication option and click on it
  4. Follow some simple on-screen instruction
You will able to enable two-factor authentication (2FA) on Instagram.
