Speed up your computer is to optimize its performance by focusing on system settings and external factors.
Start by disabling unnecessary visual effects, like animations and shadows, which can consume resources. In Windows, go to Control Panel > System > Advanced System Settings, and under the Performance section, click Settings to adjust for best performance.
On Mac, reduce transparency and motion effects through System Preferences > Accessibility. You can also disable background apps that run constantly, consuming memory and CPU power, via Task Manager on Windows or Activity Monitor on Mac.
Lastly, make sure your drivers, particularly graphics and chipset drivers, are updated to improve overall efficiency.
