How do you use dism /online /cleanup-image /restorehealth to fix system problems?
Ymiclaka
I found the command dism /online /cleanup-image /restorehealth while troubleshooting Windows errors. I want to know how it works and when it should be used. Does it repair corrupted system files or fix update problems? A clear explanation of its purpose and steps would really help.
In Microsoft Windows, DISM /Online /Cleanup-Image / RestoreHealth command is used to repair damaged system files and to fix update-related problems. Command Prompt will appear and should be opened as an Administrator, and then the command must be entered and Enter key pressed. The tool scans the windows picture and downloads healthy files where necessary. Once it is completed, re-boot your computer. A follow-up run of the System file checker (SFC) may also help to check and fix any lingering system file issues.
DISM repairs corrupted Windows system files.
Steps:
  1. Open Command Prompt as Administrator.
  2. Type: dism /online /cleanup-image /restorehealth
  3. Press Enter and wait for the scan to finish.
It checks and restores damaged system files using Windows Update or a local repair source. Restart your PC after completion.
The dism /online /cleanup-image /restorehealth command is used to repair corrupted Windows system files and restore damaged system images. It scans the operating system for issues and downloads healthy files from Windows Update if needed. Running dism /online /cleanup-image /restorehealth can fix update errors, boot issues, and overall system instability effectively.
You can use dism /online /cleanup-image /restorehealth in Command Prompt with administrator rights to repair Windows image corruption. This tool checks for damaged components and automatically restores missing files. The dism /online /cleanup-image /restorehealth command is commonly used when Windows crashes, updates fail, or system performance becomes unstable over time.
The dism /online /cleanup-image /restorehealth command helps fix Windows system problems caused by corrupted or missing files. It connects to Windows Update servers to replace damaged components with clean versions. To use dism /online /cleanup-image /restorehealth correctly, open Command Prompt as administrator and wait for the repair process to complete fully.
Running dism /online /cleanup-image /restorehealth can repair corrupted Windows images that cause startup failures, update problems, or application crashes. The command scans system health and restores damaged files automatically. Many users combine dism /online /cleanup-image /restorehealth with the SFC scan tool for a complete Windows repair and better operating system stability.
The dism /online /cleanup-image /restorehealth command is a powerful Windows troubleshooting tool designed to restore system integrity. It fixes corrupted files, damaged update components, and image-related errors that affect performance. To resolve system problems, launch Command Prompt as administrator, run dism /online /cleanup-image /restorehealth, and restart the computer after completion.
You can run DISM /Online /Cleanup-Image /RestoreHealth through Command Prompt as Administrator. Just search for CMD, right-click it, and choose Run as administrator, then type the command and press Enter. It scans Windows image files and repairs corruption by downloading healthy files from Windows Update if needed. It can take 10–30 minutes, and sometimes it may look stuck, so just let it finish. I usually run sfc /scannow afterward as well since the two commands work well together for fixing system issues.
