How does iPad wireless charging work?
How does the iPad wireless charging works? Can someone tell me the correct process ?
iPad wireless charging works through a technology called Qi charging. Here's the process:
  1. Ensure Compatibility: The iPad must support wireless charging (iPad models with wireless charging include the latest iPad Pro models).
  2. Place on Charging Pad: Place your iPad on a compatible Qi wireless charging pad, ensuring it's centered on the pad.
  3. Power On: The charging pad should be plugged into a power source. Once the iPad is correctly positioned, it will start charging wirelessly.
  4. Check Charging Indicator: You’ll typically see a charging symbol on your iPad's screen to indicate it's charging.
That's all! Just ensure you use a good-quality charging pad and align the device correctly.
