N niyati Member Yesterday at 6:45 AM #2 Press and hold Shift, then tap Win + X, release Shift, and press U then R. This triggers an advanced restart. When the Choose an option screen appears, use the ↓ key to select Troubleshoot and press Enter. Select Advanced options → Startup Settings → Restart. After reboot, press 5 or F5 to enter Safe Mode with Networking.
J Jyoti Member Yesterday at 1:21 PM #3 How to boot Safe Mode with Internet (Windows): Restart your computer. As it starts, press F5 or Shift + F8 repeatedly. If that doesn’t work, hold Shift and click Restart from the login screen. Go to Troubleshoot > Advanced options > Startup Settings > Restart. Press 5 or F5 to boot into Safe Mode with Networking. Now you’re in Safe Mode with internet access!
S shanewarne Member Yesterday at 1:25 PM #4 To boot into Safe Mode with Internet on Windows using shortcuts: Press Windows + R, type msconfig, and press Enter. Go to the Boot tab. Check Safe boot and select Network. Click OK and restart. Your PC will now boot into Safe Mode with networking enabled.
