How to check AirPod battery on phone?
To check your AirPods battery on your phone, just open the AirPods case near your iPhone. A pop-up will show the battery levels for both the AirPods and the case. You can also swipe right on the home screen to open the Today View and see the Batteries widget if you’ve added it. Easy!
To check the AirPods’ battery, place the case close to your iPhone and a window will show the battery status. It is also possible to check the battery level in the Batteries widget on the home screen. It simplifies the task of knowing the status of both AirPods and the charging case battery.
Make sure your AirPods are either in your ears or the lid of their charging case is open and they are connected to your iPhone.
