How to check for viruses on iPhone?
AnnisHayma
I’m wondering how to check for viruses on iPhone. Are there built-in tools or apps that can scan for malware, or is iPhone generally safe from viruses?
iPhones rarely get viruses, but you can check for issues by looking for unusual battery drain, unexpected pop-ups, or apps you didn’t install. Update iOS, restart your device, and remove suspicious apps. Run a security scan using trusted apps like Lookout. If problems persist, reset settings or contact Apple Support.
