The easiest way is from the printer itself, go to its control panel and look under Network/Settings to view or print a “Network Configuration” page (it shows the IP). If you’re on Windows, you can also go to Control Panel → Devices and Printers → right-click your printer → Properties → Ports tab to see the IP, or check your router’s connected devices list. I usually just print the config page since it’s the quickest.
