Hey Guys! I'm experiencing intermittent charging issues with my iPhone. Would anyone be able to suggest a method for cleaning my iPhone's charging port and safely removing dust?
Before you begin to clean your iPhone charging port, close your iPhone. To take off dust and dirt, use a toothpick or a powdery brush or a compressed air and pass it slightly. Do not use metal objects or liquid materials. Check out the edges of the port for cleaning around it to ensure that it is connected properly. Maintaining the regular will prevent charging issues.
@Gsusangrey Hey, if you want to clean your iPhone charging port, then the Apple Store is one of the best options. @daisyfrannk and @niyati also give the right and good opinion, but in some cases, your device gets damaged during the cleaning. However, it is good to visit the Apple store or customer service center to clean your device. Hope you understand!!
Turn off your iPhone before cleaning its charging port with a toothpick, compressed air, or soft brush to gently eliminate dust and debris. The use of metal objects alongside liquid cleaners should be avoided because they can damage the device.
For cleaning iPhone charging port just use Soft brush or in market there are many tools to clear the charging port like Cleaning Putty/Gel, tooth pick, etc. And the very import thigh while cleaning is that your device should be switch off to protect from damage.
Through these tips you get all the solution .
Use a plastic or wooden toothpick to keep away from scratching the steel contacts.
Gently and slowly scrape the port's walls, heading off excessive force.
Be very careful to now not damage the delicate pins within the port.
