I’m searching for how to connect AirPods to PS5 since Bluetooth doesn’t seem to detect them. Is there a special method for how to connect AirPods to PS5? Any working solution for how to connect AirPods to PS5 would be great.
In order to play music using AirPods with a PlayStation 5, you will require a Bluetooth adapter because the PS5 will not support the Bluetooth audio directly. Insert a USB Bluetooth-compatible device into the PS5, then insert the AirPods into the pairing mode (press the button on the case until the light turns white), and then pair them with the device. After connection, it is necessary to configure the adapter as the PS5 audio output device in sound settings.
