How to do YT shorts overlay for editing?
You can add an overlay using video editing apps, CapCut, InShot, or Adobe Premiere Rush is also good. You can import your video, add text/stickers/images, then export in vertical (9:16) format.
In order to add overlays in editing YouTube shorts:
  • Select an editing App- This can include CapCut, InShot, or Adobe Premiere Rush as editing apps that work on mobile devices.
  • Import Your Video -Open your Shorts clip on the program.
  • Add Overlay -To add images, text or graphics on your video use the overlay option or sticker option.
  • Control Timing and Position - Drag the overlay layer to indicate the timing when it should appear on-screen and monitoring by the user and where it should be positioned on-screen.
  • Export Vertical (9:16) Make sure that resolution is aligned to Shorts demands (generally 10801920).
This make pro-looking entertaining Short with either text, pictures or effects overlaid!
