How to fix Arc Raiders error code 30005?
I keep encountering Arc Raiders error code 30005 when trying to launch the game, and it prevents me from playing. Has anyone else faced Arc Raiders error code 30005? I’m looking for solutions or troubleshooting steps to fix this error and get the game running smoothly.
Arc Raiders error code 30005 is usually related to Easy Anti-Cheat issues; try restarting your PC first, then verify the game files from your launcher, and repair Easy Anti-Cheat from the game’s installation folder. Also make sure your antivirus isn’t blocking the game, run it as administrator, and update Windows and your graphics drivers. If it still doesn’t work, a clean reinstall of the game can help.
I had the same issue with Arc Raiders and error code 30005. Try restarting your game and console. If that doesn't work, check the system requirements to ensure your hardware meets the minimum specs. If you're still having trouble, try reinstalling the game or checking for updates.
Arc Raiders Error Code 30005 usually means a problem with Easy Anti-Cheat or game files. To fix it:
  1. Restart your PC.
  2. Run the game as administrator.
  3. Open the game folder and repair Easy Anti-Cheat.
  4. Turn off your antivirus or firewall temporarily.
  5. Verify or reinstall the game if needed.
These steps often fix corrupted or blocked service issues.
Error Code 30005 in ARC Raiders is usually caused by a problem with Easy Anti-Cheat (EAC). The game fails to launch because the EAC service, driver, or files are corrupted, blocked, or already in use by another process.
The simplest fix is to repair Easy Anti-Cheat. Open an Administrator Command Prompt, navigate to the EasyAntiCheat_EOS folder, and run the repair tool. Many players report that this restores the missing or damaged EAC components and allows the game to launch normally.
Antivirus and firewall software can sometimes block EAC files. Adding exceptions for ARC Raiders and Easy Anti-Cheat, or temporarily disabling security software for testing, can resolve launch failures caused by file-access conflicts.
If repair doesn't work, delete the corrupted EasyAntiCheat driver file and let the game reinstall it. Some users need to boot into Safe Mode first because Windows may keep the file locked. After restarting, launching the game usually recreates the missing files automatically.
If the error persists, verify game files through Steam or Epic Games Launcher and reboot your PC. Community reports suggest that a clean EAC reinstall combined with file verification fixes most stubborn Error 30005 cases.
