How to fix encoding problems in CSV after vCard to CSV conversion?
tylerhoward
Encoding problems in CSV (like weird characters or broken names) usually happen because of incorrect encoding during or after conversion. You can fix it manually, but it’s even better if you prevent it from the start.
Manual way (to fix encoding after conversion)
If your CSV already has issues, try this:
  1. Open the CSV file in Notepad
  2. Go to File → Save As
  3. Choose UTF-8 in encoding
  4. Save the file
  5. Now open it in Excel or import into Gmail
Or in Excel:
  • Go to Data → From Text/CSV
  • Select your file
  • Choose UTF-8 encoding before loading
This usually fixes most character issues.
Better way (prevent the issue during conversion)
Instead of fixing it later, you can avoid encoding problems completely by using a reliable tool like
WholeClear VCF to CSV Converter
  • Maintains proper UTF-8 encoding during conversion
  • Keeps all contact details correctly formatted
  • Supports bulk VCF files without data loss
  • No manual corrections needed after conversion
What this really means
Manual fixes work, but they take time and aren’t always perfect. Using a good tool makes sure your CSV is clean and ready to import into Gmail right away.
Tip: If your contacts include special characters or multiple languages, always go with UTF-8 — that’s the safest option.
