How to fix iPad pro screen discoloration?
A simple restart can resolve temporary glitches:
  • Press and hold the Power button and either Volume button until the power-off slider appears.
  • Slide to power off, wait a few seconds, then turn it back on.
To fix iPad Pro screen discoloration, try restarting the device, updating iOS, or resetting display settings; if the issue persists, it may need professional repair for hardware faults.
To fix screen discoloration on your iPad Pro, try these steps:
  • Restart your iPad – A simple reboot can resolve temporary display glitches.
  • Update iOS – Go to Settings > General > Software Update and install any available updates.
  • Reset display settings – Go to Settings > Accessibility > Display & Text Size and reset any custom display options.
  • Turn off True Tone/Night Shift – Disable these in Display settings to check if color shifts are the cause.
  • Inspect for physical damage – Discoloration from drops or pressure may need Apple support.
  • Contact Apple Support – If the issue persists, it could be hardware-related and may require repair.
To fix Instagram crashing, try these steps:
1. Restart the App: Close and reopen Instagram.
2. Restart Your Device: Turn off and on your smartphone.
3. Check Internet: Ensure a stable connection.
4. Update the App: Install the latest version from the App Store or Google Play.
5. Clear Cache (Android): Go to Settings > Apps > Instagram > Storage > Clear Cache.
6. Reinstall the App: Uninstall and reinstall Instagram.
7. Check Storage: Ensure enough device storage.
8. Permissions: Grant necessary permissions in settings.
If issues persist, contact Instagram support.
Screen discoloration on an iPad Pro can be caused by software glitches, hardware issues, or screen damage. First, try a forced restart by quickly pressing and releasing the Volume Up button, then the Volume Down button, and holding the Power button until the Apple logo appears. If the issue persists, check for a software update under Settings > General > Software Update. If that doesn’t resolve it, it may be a hardware issue, and visiting an Apple Store or authorized service provider is recommended.
When the screen of your iPad Pro has a discolored appearance, reboot the device and do a software update. Check the display adjustments such as True Tone, Night Shift and Color Filters. Make a force restart or reset all settings (will not delete data). In case the problem is frequent, it can be hardware-related- contact Apple support.
