How to fix TFT unlock tool no internet connection?
Hey, Does anyone know how to fix TFT unlock tool, no internet connection? Please help!
If you're encountering the "No Internet Connection" error with the TFT Unlock Tool, even though your internet is working, it’s usually due to one of the following issues:
Check Internet Connection
Run as Administrator
Disable Antivirus/Windows Defender Temporarily
Check Firewall Settings
Use VPN (If Region Blocked)
Correct Date & Time Settings
Reinstall or Use the Updated Version
Hope this helps!!
