How to fix the bright spot iPad screen?
To fix a bright spot on your iPad screen, try gently massaging the area with a soft cloth, restart your iPad, or update the software. If it persists, it may be a hardware issue—contact Apple Support.
To fix a bright spot on an iPad screen, try a gentle screen massage with a soft cloth to redistribute pixels. If that fails, a screen replacement may be needed. Avoid pressing hard. For best results, visit an authorized Apple service provider.
A bright spot on your iPad screen is usually caused by uneven pressure or damage beneath the display — often from a swollen battery, pressure on the back of the screen, or screen delamination.
To fix a bright spot on your iPad screen, first try restarting or updating the device, as software glitches can sometimes cause display issues. If the spot persists, it may be due to pressure damage, backlight bleed, or a hardware defect. Gently massaging the area with a soft cloth might help if it's a minor pressure issue. For permanent fixes, especially for hardware-related problems, visiting an Apple Store or authorized repair center is recommended.
