How to Ground Yourself Properly Before Touching PC Components?
claribel
Member
I’m about to install some new RAM and a fresh GPU, but I’m terrified of frying my motherboard with static electricity. Can someone explain how to ground yourself effectively if you don't own an anti-static wrist strap? I’ve heard that keeping the power supply plugged in but switched off while touching the metal case works, but I want to make sure I’m following the safest procedure possible to avoid any permanent hardware damage.
