How to pair AirPods to a Chromebook?
To pair AirPods with a Chromebook, open the Bluetooth settings on your Chromebook and turn Bluetooth on. Then, put your AirPods in pairing mode by pressing and holding the button on the back of the case until the light flashes white, and select them from the list on your Chromebook.
Turn on your Chromebook’s Bluetooth → open AirPods case lid → press and hold the setup button on the case until the light flashes white → select AirPods from Chromebook’s Bluetooth list to connect.
In a few simple steps you can pair your AirPods with a Chromebook. Firstly, make sure that your earphones are in the pairing mode by pressing and holding the case's button until the light blinks white. Then, head to the Quick Settings section of the Chromebook, activate Bluetooth, and choose "Pair new device" to connect to your AirPods from the list.
Open your Chromebook’s Bluetooth settings, turn Bluetooth on, then select your AirPods from the list to pair them.
To pair AirPods with a Chromebook, open your Chromebook’s Bluetooth settings from the bottom-right menu. Then, open the AirPods case lid and press the button on the back until the light flashes white. Select your AirPods from the list of available devices to connect. Once paired, your Chromebook will remember the AirPods automatically.
