How to remove followers on twitter without blocking them permanently?
I am looking for a safe method on how to remove followers on twitter. Is there an official feature that explains how to remove followers on twitter?
Will someone be notified if I learn how to remove followers on twitter correctly?
Yep Twitter (now X) has an official Remove Follower option—go to your followers list, click the three dots next to the person, and select Remove. They won’t get a notification, and it’s safer than blocking because it doesn’t permanently cut them off.
On X (Twitter), you can remove followers without permanently blocking them by briefly using the Remove follower option. Go to the follower’s profile, tap the three dots, and select Remove this follower. They won’t be notified, and you can still interact with or re-allow them later.
To learn how to remove followers on Twitter without blocking them:
  1. Open Twitter and go to your Profile → Followers.
  2. Find the follower you want to remove.
  3. Tap the three dots (More) next to their name.
  4. Select Remove this follower and confirm.
    They’ll no longer follow you, but aren’t blocked.
Here’s a simple guide on how to remove followers on Twitter safely
  1. Open your Twitter account.
  2. Navigate to your Followers list.
  3. Locate the follower you wish to remove.
  4. Click the three dots → Remove this follower.
  5. Confirm.
    The follower is removed quietly without being blocked.
If you want to know how to remove followers on Twitter without permanent blocking:
  1. Log in to Twitter.
  2. Go to your Profile → Followers.
  3. Find the follower to remove.
  4. Tap More (three dots) → Remove this follower.
  5. Confirm.
    They are removed but can still visit your profile.
Wondering how to remove followers on Twitter discreetly? Follow these steps:
  1. Open Twitter and go to your Followers.
  3. Tap the three dots → Remove this follower.
  4. Confirm removal.
    This removes them without blocking or notifying them.
How to remove followers on Twitter without blocking them permanently:
  1. Open the Twitter app or website.
  3. Find the follower you want to remove.
  4. Tap the three dots (More) → Remove this follower.
  5. Confirm your choice.
    The follower is removed, but they are not blocked, and they won’t be notified.
