How to unhide a Facebook post easily?
To unhide a Facebook post easily, go to your profile and tap the three-dot menu to access your Activity Log. From there, choose “Hidden from profile” in the “Your Posts” section. Find the post you want to unhide, tap the three dots next to it, and select “Add to profile” or “Unhide from timeline.” The post will then be visible on your profile again. This works for both desktop and mobile versions of Facebook.
Want to unhide a post on Facebook? Here's how to do it easily:
  1. Open Facebook and go to your profile.
  2. Tap the three dots (•••) under your profile picture.
  3. Select “Activity Log.”
  4. Tap “Hidden from profile.”
  5. Find the post you want to unhide and tap the three dots next to it.
  6. Choose “Add to profile.”
That’s it! Your post is now visible again.
To unhide a Facebook post, go to your profile and click on Activity Log from the menu. In the left sidebar, select Hidden from profile. Here you’ll see all the posts you’ve hidden. Find the post you want to unhide, click the three dots (⋯) next to it, and select Add to profile or Unhide. That’s it! The post will now reappear on your timeline just like before.
To unhide a Facebook post easily:
  1. Go to your profile.
  2. Click the three dots (...) under your cover photo.
  3. Select Activity Log.
  4. In the left menu, choose Hidden from profile.
  5. Find the post, click the circle with a line icon, and select Add to profile.
This will unhide the post and make it visible on your timeline again.
To unhide a post on Facebook, please visit your profile, select the three dots and then choose Activity Log. There, tap on Hidden from profile. To unhide it go to the post you wish to unhide, tap on the three dots beside the post and tap on add to profile.
To unhide a Facebook post, go to your profile and click on the three dots (...) next to the "Edit Profile" button, then select Activity Log. In the Activity Log, tap "Hidden From Profile" from the filters. Find the post you want to unhide, tap the three dots next to it, and select "Add to profile" or "Unhide from profile." The post will then be visible on your timeline again.
