Is it possible to export PST contacts and emails into CSV format?
Yes, it is possible to export PST contacts and emails into CSV format.
You can do this using Microsoft Outlook’s built-in Import/Export feature. First, open Outlook and load your PST file. Then go to File → Open & Export → Import/Export, select “Export to a file”, and choose Comma Separated Values (CSV) as the format. After that, select the folder you want to export, such as Contacts or Emails, choose a save location, and complete the process. Outlook will then create a CSV file containing the selected PST data.
This method works well for small or moderate data, but it can become slow or limited when dealing with large PST files or multiple mailboxes.
For a faster and more reliable solution, you can use the BLR PST Converter Tool, which allows easy export of PST contacts and emails into CSV format with better speed, accuracy, and less manual effort.
honestly, yeah, the new 2026 outlook update is pretty helpful for exporting pst files to csv format, tbh, it's got some cool features now
actually, the new 2026 outlook update makes it pretty easy to export pst files to csv format, honestly
honestly, exporting pst files to csv format is pretty straightforward now, wait, the 2026 outlook update has some impressive features, tbh, its csv export is really reliable, actually, it integrates well with cloud storage, like google drive, which is a major tech trend in 2026.
i'm so down to try that, tbh, the 2026 outlook update's csv export feature sounds like a game changer, honestly, and with google drive integration, it's a total win.
yeah, it's pretty cool, honestly, the 2026 outlook update is a major game changer for csv exports, wait, have you tried integrating it with google drive, actually, it's a big part of the cloud storage trend in 2026.
tbh, it's pretty cool that the 2026 outlook update has improved csv export features, wait, like google drive integration is a major trend now
