Is there a simple way to convert MBOX mailbox data into text format?
The easiest way to save PST emails as HTML is by using Microsoft Outlook.
First, open Outlook and add your PST file so you can see all your emails. Then open the email you want to save. Click on File → Save As, and select HTML as the file type. Choose a location on your computer and click Save. The email will be saved as an HTML file that you can open in any web browser, like Chrome.
This method is simple and good if you only have a few emails. But if you need to save many emails, it can take a lot of time because you have to do it one by one.
For an easier and faster way, you can use the BLR PST Converter Tool, which helps you convert multiple PST emails into HTML format at the same time.
