What can I do when PS4 console won't turn on?
If your PS4 won't turn on, try these steps:
  1. Unplug the power cord for 30 seconds and plug it back in.
  2. Check the power outlet and cable.
  3. Press and hold the power button for 7 seconds to start in Safe Mode.
  4. Try a different power cable if available.
    If it still doesn’t work, you may need professional repair.
Disconnect it and connect it back after 30 seconds, make a switch of power outlet or cable, and hold the power button for more than 7 seconds to enter Safe Mode. In case of failure, contact Sony support.
