What does the gaping hole NYT article refer to?
I came across the term “gaping hole NYT” and I’m not sure what it means in the article. Can someone explain the context and why it’s significant? Any insights or breakdowns of the article would be really helpful!
The gaping hole in a New York Times story is usually a major lack or failure which may be a lapse in policy or budget, security flaw, or unmet social need, a serious issue which needs to be addressed, reformed, or held accountable.
In a New York Times article, “the gaping hole” usually refers to a major shortfall or absence, often describing a budget deficit, funding gap, policy failure, or missing solution that has serious consequences.
The “gaping hole” NYT article refers to a widely discussed critique of a significant gap or flaw in a system, policy, or narrative highlighting something important that was overlooked or underreported.
