What is the Snap solar system, and how does it work?
What is the Snap Solar System?​
Snap Solar is a solar power system that helps you use the sun’s energy to power your home.
How it works:​
  1. Solar panels collect sunlight.
  2. That sunlight turns into electricity.
  3. You use the power, store it, or send extra back to the grid.
It’s a clean way to cut your power bills and use less from the grid.
