What’s the Best Motherboard for 9800X3D for Gaming and Overclocking?
I’m building a new PC with the Ryzen 9800x3d and want to know the best motherboard for 9800x3d in terms of thermals, BIOS features, and gaming performance. Any real user experiences?
In case you desire the safest path to gaming + some OC on the 9800X3D, X670E/X870E and do not afford to spare VRMs. I would choose between the ASUS ROG Strix / Crosshair X670E or the MSI MEG X670E ACE these have large VRMs and established BIOSes and can easily deal with PBO/Curve Optimizer and memory tuning. They are cooler when subjected to constant loads like AVX and the BIOS tools to get things right are not as much of a pain as the cheap boards. At least, at that place I would spend my money in case you are interested in thermals and stability, rather than flashy RGB.
Mostly 9800X3D is a gaming monster, not a workstation chip that goes out of control on power consumption, hence you do not need the absolute 22-phase flagship. An X670E or even the B650E (Tomahawk-class) will be very high FPS with low temperatures. Use the saved money on a good AIO or faster DDR5 instead - 1440/4K gaming performance is larger due to GPU/ram than a solid X670E with the ultraflagship.
When you overclock the 9800X3D so hard that it can fit every frame, purchase X870E Taichi or ACE you need the VRM clearance.
I do not think so; X870E is too much of a performance for the average game player. 9800X3D enjoys good cooling and memory setups better than the hot-end VRM levels. Most 500 -1 Tomahawk level boards with good cooling = optimal price/perf.
Reasonable but long-term stability and throttling during long sessions can be prevented with an addition of extra VRM cooling.
(Divisions in the community between benching and nonstop gaming)
This was constructed off a 9800X3D on an X670E AORUS Master - BIOS updates were smooth, the temperatures were fair and I actually forgot to stress-test after a week due to the seamless running of games. Hint: download BIOS and update before you change XMP / EXPO - averted a bizarre boot cycle. In addition, individuals in discussion boards are perpetual complainers; the majority of the boards are okay as long as one does not attempt to drive them in a desert.
In the short list: ASUS ROG Strix / Crosshair (X670E/X870E) / MSI MEG X670E ACE/ Gigabyte AORUS Master / X870E / ASRock X870E Taichi. To install thermals Choose large VRM heatsinks and excellent M.2 cooling on pick boards; To tuning features (BIOS) choose either ASUS/MSI to polish the UI and regular firmware updates; To performance any of these will be the best - make sure the memory kit is compatible and update the BIOS first. A B650E Tomahawk-class board is also still capable of doing really well on pure gaming, were its user just budget-conscious.
The finest motherboard for a high-powered Ryzen 7 9800X3D build is an X870E, such as the ASUS ROG Crosshair Hero. It has first-rate VRMs and cooling, which are perfect for a stable overclock and hence getting the most gaming performance out of the high-speed DDR5 RAM.
The Gigabyte X870E AORUS Elite WiFi 7 is the best motherboard for the 9800X3D, offering strong VRMs, PCIe 5.0, and top gaming/overclocking stability. For a cheaper option, the MSI X670E Gaming Plus WiFi is a great mid-range pick.
