Which tool is best for bulk Excel to VCF conversion?
tylerhoward
For bulk Excel to VCF conversion, the best tool is usually one that supports XLS/XLSX files, field mapping, and accurate contact export without data loss. When users try to convert large contact lists manually, they often run into problems like incomplete imports, formatting errors, or mismatched fields. One practical option is WholeClear Excel to vCard Converter. It helps convert Excel contacts into VCF format in bulk and is useful for users who need to transfer many contacts at once. The tool supports proper mapping of columns such as first name, last name, phone number, email, company, and address, which helps maintain contact accuracy.This kind of software is helpful if you want to import contacts into Android phones, iPhones, Gmail, Outlook, or other applications that support VCF files. For bulk contact databases, a dedicated converter is usually much faster and more dependable than manual steps.
