Why does CSV to VCF conversion cause missing names or blank contact fields?
tylerhoward
I ran into this issue when I tried to convert CSV to VCF and noticed names or fields go missing because the CSV columns don’t catch vCard fields properly. For example, “First Name” and “Last Name” may not be recognized, so they import as blank. Empty cells in CSV are also skipped during conversion. I’d suggest checking field mapping before exporting. Using a tool like WholeClear CSV to VCF Converter is a smart choice for contact management that shows a preview and lets you map fields manually, which really helps avoid missing names or blank contact details.
