Antigravity Agent Terminated Due to Error – How to Fix?
Olivier
Member
I keep seeing the message antigravity agent terminated due to error on my system and I don't know what's causing it. It seems to affect performance as well. Has anyone encountered this and found a solution?
It means the Antigravity Agent crashed or stopped unexpectedly.
Fix:​
  • Restart app/device
  • Run as administrator
  • Reinstall the agent
  • Disable antivirus temporarily
  • Update to latest version
The “Antigravity Agent terminated due to error” issue is usually caused by temporary glitches, server overload, or misconfiguration. The quickest fix is to restart the agent, refresh your session (log out and back in), and try running the task again. If it persists, check logs for errors, disable problematic extensions, switch the AI model, or clear cache/reinstall these steps solve most cases quickly.
Antigravity Agent error occurs due to app crashes, conflicts, or outdated software. Fix by restarting device, updating system, clearing cache, reinstalling app, disabling conflicting apps, or resetting system settings.
Restart the application and check internet connectivity. Clear cache and re-login. Update software to latest version. Disable conflicting extensions or antivirus. If issue persists, reinstall Antigravity Agent or check logs for error details and contact support for further assistance team.
The “Antigravity Agent Terminated Due to Error” message usually appears in tools that use the Antigravity Engine (often tied to automation or scraping apps). It typically means the background agent crashed or failed to start properly.
The Antigravity Agent terminated due to error message means the background agent process has crashed or stopped unexpectedly. This usually happens because of app glitches, missing permissions, or software conflicts. The fastest fix is to restart your device and relaunch the app. If the error returns, run the application as administrator and check whether your antivirus is silently blocking the agent process.
To fix the Antigravity Agent error, follow these steps: (1) Log out and log back in to refresh your session. (2) Clear the app cache from settings. (3) Update the app to the latest version — outdated builds are a common cause. (4) Disable conflicting browser extensions if you're using a web-based tool. (5) Check the error logs inside the app for a specific error message that points to the root cause.
One of the most overlooked causes of the Antigravity Agent terminated error is antivirus or firewall interference. Security tools sometimes block the agent from running in the background without showing any obvious warning. Open your antivirus settings and add the Antigravity app to the whitelist or exceptions list. After doing this, restart both the security software and the app to see if the agent runs without terminating.
If basic troubleshooting hasn't resolved the Antigravity Agent error, try switching the AI model inside the tool settings — some model versions have known stability bugs that cause agents to terminate mid-task. You can also try disabling problematic plugins or extensions one by one to identify if a specific one is causing the conflict. Most users who follow this process find the culprit within two or three attempts.
The most reliable fix for a persistent Antigravity Agent terminated due to error issue is a clean reinstall. Uninstall the app completely, delete any leftover files from the installation folder, and download the latest version fresh from the official source. After reinstalling, whitelist it in your firewall and antivirus. If the error still appears after all this, contact the app's support team and share your error log — it gives them the exact information they need to help you fast.
