ameliaroberts
There are some manual ways to export EML files using email clients like Thunderbird to import EML files and export them as MBOX. This method works but the process can be time-consuming, especially when dealing with bulk EML data or keeping folder structure and attachments. If you are looking for a simple method then you can consider using a dedicated tool. I’ve seen people use GainTools EML to MBOX Converter for this task since it automates the process and minimizes the risk of data loss. It can be helpful if you want a quick and user-friendly solution without too much manual effort.
