Do Pinterest collections need to be public, or can they be kept private?
Summerap
Hi everyone, I’m trying to organize my ideas on Pinterest but I’m not sure if collections have to be public by default. I’d prefer to keep some of them private or limited to certain people. Has anyone done this before or knows how the privacy settings work?
You can actually keep your Pinterest collections private, which is really useful if you're planning something personal like a surprise party or a wedding. When you create a new board, you have the option to set it to secret, which means only you and anyone you invite can see it. You can also set it to private, where you can choose who to share it with, so it's not publicly visible. To do this, just click on the three dots on your board and go to settings, then choose who can see your board, it's pretty straightforward and gives you control over who sees your collections.
On Pinterest, people call "collections" of items boards. These boards may be public or private. Public boards will show to everyone and may come up in search results whereas private boards (also called secret boards) are only shown to you and any of the persons you invite. This feature allows you to work on projects, save inspirations, or organize materials secretly. Besides that, you can change the visibility of a board anytime in the settings. Also, if you are a parent or a younger user, by keeping the boards private, you can have more control over what is shared and who can see the saved content.
There are two types of Pinterest boards or collections; the first type is public boards, and the other is secret boards. Secret boards refer to those boards that can be kept private by turning on the “secret board” option; this way, only you and those who have been invited to collaborate can view them.
Pinterest collections (boards) can be either public or private. Public boards are visible to everyone and help with discovery, while private boards are only accessible to you or invited collaborators, making them ideal for personal planning or confidential projects.
Pinterest collections (boards) do not need to be public — you can keep them private using the Secret Board option. When creating a board, toggle the "Keep this board secret" switch. Secret boards are only visible to you and anyone you personally invite. They won't appear in search results or on your public Pinterest profile.
To make a Pinterest collection private, open the board, tap the three-dot menu, and select Edit Board. Toggle on the "Secret" option and save. This immediately hides the board from public view. You can also do this when creating a new board from scratch. Existing boards can be switched between public and private at any time from board settings.
Pinterest private collections can still be shared with specific people. Inside a secret board, use the Invite option to add collaborators by email or username. Only invited members can view or pin to the board. This is perfect for planning events like weddings or surprise parties without making your ideas visible to the general public.
Public Pinterest boards appear in search results and on your profile, helping others discover your content. Private (secret) boards are hidden from everyone except invited collaborators. Choose public if you want engagement and followers. Choose private if you're saving personal ideas, planning projects confidentially, or organizing content you're not ready to share with the world.
On Pinterest Business accounts, private collections work the same way as personal accounts — boards can be set to secret at any time. However, note that secret boards don't get indexed by Pinterest or Google, so they won't contribute to your SEO or content discovery. Use public boards for marketing and private boards for internal planning or draft content.
