Instagram's dark mode for DMs is usually tied to your phone’s system-wide settings. On both Android and iOS, you can enable dark mode in your device's "Display" settings, and Instagram will automatically switch. However, if you want to change it manually within the app, go to your profile, tap the three-line menu, select "Settings and Privacy," then "Accessibility," where you can toggle "Dark Mode" on.
