How do I fix eu5 packagingresults: error: unknown error in UE5?
Mateo
Member
I keep hitting eu5 packagingresults: error: unknown error every time I try to package my project, but the logs don't show a clear cause. Has anyone else run into this and found a reliable fix? Any help with the packaging pipeline would be appreciated.
That “unknown error” in UE5 packaging is usually just a generic message hiding the real issue, so the first thing I’d do is open the full Output Log (not just the summary) and scroll up to find the actual error line. In my experience, it’s often caused by missing plugins, invalid file paths (like spaces or long names), or a bad asset/blueprint that fails to compile, so try fixing any warnings in your project first, delete the Saved, Intermediate, and Binaries folders, then package again. Also make sure your project name has no special characters and all required SDKs are installed. Most of the time, once you fix the real error in the log, this “unknown error” disappears.
The packaging results: unknown error in UE5 is typically due to missing assets, project settings, or plugin incompatibilities. So check the Output Log for the line that failed. Next, clear the Intermediate, Saved, and DerivedDataCache folders, check the plugins and validate the assets. Rebuild and repackaging.
That error is usually just hiding the real issue, so open the full Output Log and scroll up to find the actual cause, then delete your Saved, Intermediate, and Binaries folders and try packaging again, that fixes it most of the time.
The "Unknown Error" is a generic message masking specific issues. To fix it, check the Output Log for the actual error line, then delete the Binaries, Intermediate, and Saved folders. Ensure there are no spaces in file paths, validate your assets, and confirm all required plugins are active.
The “PackagingResults: Error: Unknown Error” in Unreal Engine 5 usually means a hidden build issue. Check the Output Log for the real error, then fix it by deleting Intermediate and Saved folders, repairing missing assets, disabling plugins, and ensuring Visual Studio is properly set up.
