How do I fix phone charging but CarPlay not working?
Olivia
Member
Hey Guys! I am facing a problem with my CarPlay. I don't know what the issue is, but my phone is charging, but CarPlay is not working. Could anyone please tell me what the reason could be and how I can fix it?
If your phone is charging but CarPlay isn’t working, here are some things to check and try:
  • Use an Apple-certified cable – Faulty or low-quality cables can charge your phone but not support data transfer, which CarPlay needs.
  • Check USB port compatibility – Some car USB ports only charge. Try a different one labelled for data or CarPlay.
  • Restart your phone and infotainment system – A simple reboot can reset the connection.
  • Ensure CarPlay is enabled – On your iPhone, go to Settings > General > CarPlay and make sure your car is listed and allowed.
  • Update iOS and car software – Outdated software can cause connection issues.
  • Try another phone or cable – This helps rule out whether it’s your phone or the car’s system.
  • Reset network settings – Go to Settings > General > Transfer or Reset iPhone > Reset > Reset Network Settings.
If none of these work, your car system may need a firmware update or a check at a service center.
