How to boost internet speed on PS5?
Prakhar02
I'm looking for tips to improve my internet speed on my PS5. I've been experiencing some lag and slow download times lately.
Any advice on optimizing network settings, router configurations, or anything else that might help?
To boost PS5 internet speed, use a wired connection, switch to 5GHz Wi-Fi, and set Google (8.8.8.8) or Cloudflare (1.1.1.1) DNS. Restart your router, reduce network congestion, and enable QoS for gaming priority. Use Rest Mode for faster downloads. If issues persist, contact your ISP.
With the following simple steps, you can improve your internet speed and connectivity, which will lead to a better overall performance.Wish to set your PS5 into gaming-gear mode?
1. Use an Ethernet connection to speed things up.
2. If using Wi-Fi, ensure it is configured to the 5GHz band and stay near the router.
3. Check speed via PS5 settings.
4. Switch DNS settings to Google (8.8.8.8) or Cloudflare (1.1.1.1).
5. Shut other apps screwing up with the Internet.
6. Update the software of your PS5 and router.
7. Restart the router and PS5.
8. Use QoS to prioritize the PS5.
9. If the router is old, consider a new one.
10. Limit the number of devices on the router.
