I keep getting an ERR_CONNECTION_REFUSED Error message when trying to access certain sites. What are the common causes, and what steps can I take to resolve it? Any quick fixes would be great.
To fix ERR_CONNECTION_REFUSED Error, restart your browser and router, then check if the website is down. Disable VPN, proxy, or firewall temporarily. Clear browser cache, flush DNS, and try different DNS servers. Ensure no security software is blocking the site. Reset network settings if the issue persists.
“ERR_CONNECTION_REFUSED” appears when Chrome can’t connect to the website’s server. Fix it by restarting your router, checking your internet, and ensuring the site isn’t down. Disable VPN, proxy, or suspicious extensions. Clear Chrome cache, flush DNS, reset network settings, and review firewall or antivirus rules that may be blocking the connection.
To fix the ERR_CONNECTION_REFUSED error, start by checking your internet connection and restarting your browser or router. Clear your browser cache and disable extensions that might block connections. Temporarily turn off antivirus or firewall software to see if they’re causing the issue. Try accessing the site in Incognito Mode or another browser. If the site itself is down, wait and try again. You can also flush DNS, renew your IP, or reset network settings to restore access.
To fix the ERR_CONNECTION_REFUSED error, check your internet connection, restart your router, disable VPN or firewall temporarily, clear browser cache, reset DNS settings, and ensure the website server isn’t down or blocking your access.
