How to Fix the ERR_CONNECTION_TIMED_OUT Error?
Asthanf
Member
I keep getting an ERR_CONNECTION_TIMED_OUT error when trying to load certain sites. What usually causes this issue, and what are some quick ways to troubleshoot and fix it? Any guidance would help.
ERR_CONNECTION_TIMED_OUT Error Fixing To troubleshoot the err_connection_timed_out error, the quickest solution would be to check your connection, reboot your router, and delete your browser's cache.
To fix the ERR_CONNECTION_TIMED_OUT error, first check your internet connection and restart your router. Clear your browser cache and cookies, disable VPN or Proxy, and turn off the firewall/antivirus temporarily. You can also flush DNS using ipconfig /flushdns in Command Prompt and try using a different browser or device. If the website is down on the server side, wait and try again later.
Steps to resolve ERR_CONNECTION_TIMED_OUT include internet connection check, router reboot, VPN/firewall disconnection, browser cache removal, DNS reset, DNS flush, and viewing a site on a different network.
