How to Take a Screenshot on a Surface Pro?
Winter
Member
I’m new to using a Surface device and need help with How to Take a Screenshot on a Surface Pro. What are the easiest keyboard shortcuts or built-in tools available? Also, where are screenshots saved after capturing them on a Surface Pro?
On a Surface Pro, press Windows + Volume Down to take a screenshot, or use Windows + Shift + S for the Snipping Tool. Your screenshots are saved automatically in Pictures → Screenshots.
On a Surface Pro, press Windows + Volume Down simultaneously to take a screenshot. The screen briefly dims, and the image is saved automatically in the Screenshots folder under Pictures. You can also use Windows + Shift + S to capture a selected portion using Snipping Tool.
To take a screenshot on a Surface Pro, press Windows + Volume Down for the whole screen, or Windows + Shift + S to use Snip & Sketch for a custom area. Screenshots save to the clipboard or Pictures folder.
To take a screenshot on a Surface Pro, press Windows + Shift + S to use Snipping Tool. For a full-screen capture, press Windows + Print Screen. On older models, press Power + Volume Down together. The screenshot is saved automatically.
