K Kartik Wadhwa New member Mar 27, 2025 #1 Can anyone tell me how I can enable dark theme on my Snapchat ID?
G Gsusangrey Member Mar 27, 2025 #2 Here is how you can enable Dark Mode on Snapchat on your Android phone: Open Phone Settings > Display. Turn on Dark Theme (or Night Mode). Reopen Snapchat—it should auto-adjust. Upvote 0 Downvote
O Olive Member Feb 16, 2026 #3 Open the Snapchat app on your Android phone and tap your profile icon at the top-left. Tap the Settings () icon to open app settings. Scroll down and select App Appearance. Choose Always Dark to enable dark mode. This is How to turn on dark mode on Snapchat on Android easily. Upvote 0 Downvote
C charlesrich Member Feb 16, 2026 #4 Open the Snapchat app on your Android device. Tap your Bitmoji/profile icon in the top-left corner. Select the Settings (gear icon) in the top-right. Scroll down to App Appearance. Choose Always Dark to enable dark mode. If unavailable, update the app. Now you know How to turn on dark mode on Snapchat on Android easily. Upvote 0 Downvote
S StormyHuda Member Feb 16, 2026 #5 Launch Snapchat on your Android phone. Tap your profile icon (Bitmoji). Open Settings using the gear icon. Find App Appearance in the menu. Select Always Dark option. Update app if missing. This is How to turn on dark mode on Snapchat on Android quickly. Upvote 0 Downvote
W Warreneduth New member Feb 16, 2026 #6 Open the Snapchat app. Go to your profile section. Tap the Settings icon. Scroll to App Appearance. Choose Always Dark mode. Restart app if needed. Follow these steps for How to turn on dark mode on Snapchat on Android successfully. Upvote 0 Downvote
E Ernest Member Feb 16, 2026 #7 Start Snapchat on Android device. Tap Bitmoji in top corner. Enter Settings (gear icon). Locate App Appearance option. Tap Always Dark to activate. Ensure latest version installed. That’s How to turn on dark mode on Snapchat on Android easily. Upvote 0 Downvote
