Khushi Member Apr 16, 2025 #1 Is it possible to use iPad as second screen for a Mac with cable? If yes, please tell me how to do so!
J James Member Apr 17, 2025 #2 To use your iPad as a second screen for your Mac with a cable: Connect your iPad to your Mac using a USB cable. On your Mac, open System Preferences > Displays. Click Add Display and select your iPad. Your iPad will now work as a second display!
J jainnorton Member Jun 5, 2025 #3 To use an iPad as a second screen for your Mac with a cable, you'll use the Apple's Sidecar feature. You'll need a compatible iPad and Mac, a USB cable (or Lightning to USB cable), and macOS Monterey or later.
