techeianjali
Member
You can change MBOX to TXT without losing important information, but it depends on how you do it.
You can open your MBOX file in Mozilla Thunderbird and use the Save As option to save emails as TXT files. This works well for simple things like the subject, sender, and body of the message. TXT format, on the other hand, is just plain text, so it won't keep formatting, images, or attachments.
The BLR MBOX Converter Tool helps convert data more quickly and accurately, especially when there are a lot of emails. It also makes sure that all important information stays intact during the process.
Using an mbox to pst converter can also help you manage and convert your email data better if you need to be able to use it in other formats in the future.
You can convert MBOX to TXT without losing important information, but remember that TXT files can only hold plain text.
