Can AirPods connect to Android phones?
Yes, Airpods can be connected to Android phones using the Bluetooth connection. Open the AirPods case, press the pairing button located on the back of the case, and you will have to go to the Bluetooth settings of your Android device and choose the AirPods option. Some features such as Siri and automatic ear detection are restricted though.
Yes, it is true that AirPods are compatible with Android phones as regular Bluetooth headphones. You are able to listen to music and to take calls.Nevertheless, you will forfeit much of the value of Apple - i.e., blistering pairing, automatic device switching, Siri, hands-free, and precise battery life indication of the case and each pod separately.
Yes, Android phones can as well connect to AirPods as any other Bluetooth earbuds. To connect, just go to the settings of the Bluetooth in your phone, and turn on the pairing mode of the AirPods and then, they will appear in the list of devices, and you will only need to select them.
Certainly, just like any other wireless earbuds, AirPods are able to connect via Bluetooth with Android phones. Even though you will not have some Apple-centric features like automatic switching or Siri, enjoy the advantages of good sound quality and basic controls.
